All, New version is available.Version 2.2.7 - 02/04/2011 * Added ability to define a simple marker symbol for point or the current picture marker symbol.
<simplemarkersymbol style="circle" size="12" color="0x00ffff" alpha="0.5" xoffset="0" yoffset="0" angle="0"> <outline style="solid" color="0x00ffff" alpha="1" width="1"/> </simplemarkersymbol> <!--<picturemarkersymbol url="assets/images/tick.png" height="16" width="16" xoffset="0" yoffset="0" />-->
I'm using the uncompiled version.All I did was replace the old folder with the new version folder, recompile, clear the cache and that was it, started getting the error. Then I tried it with my xml including your changes such as the enable export true elements and I get the same error. What is that error anyway?I will replace it with the old version again (2.2.3) and see if it works normally again.Nestor.
Nestor, There was an issue with 2.2.7 I have it fixed in 2.2.7f
Fields: * OBJECTID (Type: esriFieldTypeOID, Alias: OBJECTID) * Local_ID (Type: esriFieldTypeString, Alias: Local ID, Length: 10 ) * Bin (Type: esriFieldTypeInteger, Alias: Bin) * Length_ (Type: esriFieldTypeDouble, Alias: Length) * B_Road_W (Type: esriFieldTypeDouble, Alias: Bridge Roadway Width (Curb to Curb)) * Deck_W (Type: esriFieldTypeDouble, Alias: Deck Width (Out to Out)) * Approach_R_W (Type: esriFieldTypeDouble, Alias: Approach Roadway Width) * Span_Num (Type: esriFieldTypeSmallInteger, Alias: Number of Spans) * M_Span_L (Type: esriFieldTypeDouble, Alias: Max Span Length) * Deck_Cond_C (Type: esriFieldTypeString, Alias: Deck Condition Code, Length: 5, Domain: Coded Values: , [9: 9 - Superior to present desirable criteria], [8: 8 - Equal to present desirable criteria], ...8 more... )
Cynthia, Hmm... I was actually refering to the one that you are attempting to use the domain for. I need to see how you are setting that expression up.
PID LIKE '[value]%' AND AAN LIKE '[value]%'</expression>
<expression alias="Advanced Query" textsearchlabel="Enter any Valid SQL Expression" field="" usedomain="false">[value]</expression>
<enableexport>true</enableexport>
You need to read the documentation carefully.
Signed in members can post, follow updates, and more. New here? Register a free account.
