Eric, You are going to have to explain in more detail. I just tested my live preview site by adding the print widget and a parcel layer with lots of annotation and the annotation on the map showed up in the map export just fine.
Eric, My test used the ExportWebMap task and the annotation part of a group and many layers of annotation are then sub grouped under the master annotation group layer. I have my test stuff on my live preview site for now. http://gis.calhouncounty.org/FlexViewer3.6/index.html?config=config-eLayerList.xml
Eric, OK, I am going to take my live preview site back to the way it was then. Hope 10.2.2 fixes things for you.
Eric:You said: "I plan on doing a fresh install of AGS 10.2.2 in the next week or so (related to a couple other AGS issues I'm having)."Can you provide some explanation on some of the issues you are having with AGS 10.2.1 (I assume that is your current version and you will be upgrading soon)?
So did you upgrade overtop of AGS v10.1 instead of uninstalling v10.1 and then installing v10.2 (not sure if this is even possible)?I know that all the AGS servers I am working with always had previous versions uninstalled, although in most cases we have entirely new servers for different AGS versions to reduce upgrade issues.
Eric:You asked"A question for you Michael - if you do a fresh install with each version update, do you use the backup utility to save you a bit of time when you do the upgrade?"My organization upgraded from v10.0 to v10.2, bypassing v10.1 entirely, so I don't believe this backup utility would have helped. I think it might help with our next upgrade, so thank you for this information.
