Editing the attribution in Flex Application Builder map
3747
7
12-04-2014 09:13 AM
GeorgeKatsambas
I cannot find or remember how to edit the attribution info in a Flex application Builder map.
RobertScheitlin__GISP
George,
   Yep you beat me to the reply button. Glad you got it figured out. Don't forget to mark this as answered.
George,
   The text in the attribution come from the map services that are used in the map. The text is from their copyright property on the map service. Is this what you are after?
GeorgeKatsambas
I think so Robert, thank you. So in the attribution where it says Strategic Services to change that it would have to be republished as a service?
GeorgeKatsambas
Actually that's what I was looking for Robert, its under credits in ArcGIS Server manager, Thanks
George,
GeorgeKatsambas
Thanks Robert, on another hand I downloaded Flex 3.7 but cannot get any results with the enhanced draw widget. I copied the zip eDraw under the folder For_AppBuilder 3.7 and added that as a widget.
George C. Katsambas, GISP
GIS Supervisor
Pace Suburban Bus
550 W. Algonquin Rd.
Arlington Heights, IL. 60005
• (847) 228 2393 Phone
7 (847)228 2330 Fax
•george.katsambas@pacebus.com
www.pacebus.com<http://www.pacebus.com/>
P Please do not print this email unless it is absolutely necessary. Spread environmental awareness.
George,
   That is not the process for adding a custom widget to the App Builder.
Refer to this link for steps to adding and removing custom widget from App Builder
Manging custom widgets
GeorgeKatsambas
George Katsambas would like to recall the message, "[ArcGIS Viewer for Flex] - Editing the attribution in Flex Application Builder map".
