Dynamically Add/Remove Layers on Widget Open/Close
3534
6
03-26-2012 10:48 AM
KeithGerhartz1
I am creating a modified Edit widget allows one to specify which layers will be added to the map and be made available for editing.
I want to dynamically add the referenced layers when the widget is opened and remove them when it is closed.
The code below works but when I reopen the widget the layers are not added to the map which makes sense as that is done in init(). However, moving it to the widgetOpenedHandler causes the layers to be redundantly added.
I see a couple of threads regarding "really closing" widgets.
Any assistance with this would be greatly appreciated.
            [Bindable]
            private var featureLayersToAdd:Array = new Array;
            [Bindable]
            private var layerArray:Array = new Array;
            private function init():void
                if (configXML) // checking for valid content in the configuration file
                    var lyrList:XMLList = configXML..layer;
                    var URL:String;
                    var name:String;
                    var layerid:String;
                    for (var i:Number = 0; i < lyrList.length(); i++){
                        URL = lyrList.@url;
                        name = lyrList.@name;
                        layerid = lyrList.@name;
                        layerArray.push({iLayerName:name,iLayerURL:URL,iLayerID:layerid});
                    for (i = 0; i < layerArray.length; i++)
                        var layerToAdd:FeatureLayer = new FeatureLayer;
                        layerToAdd.url = layerArray.iLayerURL;
                        layerToAdd.name = layerArray.iLayerName;
                        layerToAdd.id = layerArray.iLayerID;
                        map.addLayer(layerToAdd);
                        featureLayersToAdd.push(layerToAdd);
                    editor.featureLayers = featureLayersToAdd;
            private function widgetClosedHandler(event:Event):void
                for (var i:Number = 0; i < layerArray.length; i++)
                    var layerToRemove:Layer = new Layer;
                    layerToRemove = map.getLayer(layerArray.iLayerID);
                    map.removeLayer(layerToRemove);
                editor.featureLayers = [];
RobertScheitlin__GISP
Keith,
   I would suggest that you leave the code for adding the layer in the widget open handler but adding code to check if the layer is already present and if so don't add it.
                var editLayer:FeatureLayer = map.getLayer("youreditlayersid");
                if (editLayer is null)
                    //Add it code
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote) as shown below:
KeithGerhartz1
Robert,
True, and then I could just turn the layer on and off. However, the feature layer is added to the TOC when it is added to the map and I was wanting to remove it when the widget is closed to avoid redundancy and confusion. Should be a way to do this. I will keep looking and post the answer after I figure it out ... unless, of course, one of you other fine FLEXers comes to my rescue first :-).
Keith,    You would still remove the layer when the widget is closed.
RyanColeman
I'm using this to open an annexations history layer with the TimeWidget but it's not working right
            [Bindable]
            private var annexLayer:FeatureLayer = map.getLayer("Annexations");
gives me the error: Implicit coercion of a value with static type com.esri.ags.layers:Layer to a possibly unrelated type com.esri.ags.layers:FeatureLayer.
I have both
            import com.esri.ags.layers.FeatureLayer;
            import com.esri.ags.layers.Layer;
and if I change private var annexLayer:FeatureLayer to just Layer it will compile but the widget will do nothing when clicked. The code that is supposed to open the layer is this...
            protected function widgetOpenedHandler(event:Event):void
                map.timeSlider = timeSlider;
    map.addLayer(annexLayer);
Any idea what I'm doing wrong?
ReneRubalcava
Esri Frequent Contributor
Try to cast the layer to coerce the result you want.
Bindable]
private var annexLayer:FeatureLayer = FeatureLayer(map.getLayer("Annexations"));
If you read the docs on the Map::getLayer() method, you'll see it will always return a base Layer that you would need to cast to the proper type in most cases.
RyanColeman
thanks for the quick reply. That fixes the error but the widget still does nothing when clicked. It doesn't even show a problem in fiddler
