Dynamic Hyperlinks Within Search Widget Popups
4515
13
02-28-2012 05:13 AM
IsaiahAguilera
After editing the PopUpRendererSkin I have been able to have my popups listen for a specified attribute value and make them a click able hyperlink (even if the field itself is not a URL). I have had the popups with the links working great for a while now. My question is getting them to work with the search widget. I have been using a few different search widgets including the eSearch widget. But they all seem to do the same thing, even though I am pointing the widget to the PopUpRendererSkin it doesn't seem to convert the specified values into links. I know this probably has something to do with the search widget using the xml to configure its popup but if any body could help me out I would be really grateful!
RobertScheitlin__GISP
Isaiah,
   OK I need all the EXACT specific info for what you are attempting then. What field are you looking for what Values can I expect from those fields and what URLs do I replace them with.
IsaiahAguilera
I have over 50 variables in the skin. But if you could show me one or two then I will probably be able to take it from there. All I want to do is to have the popup turn a specified string into a clickable link. The skin used flex regular expression to match the strings and then converted them to a hyperlink. I have attached a picture that shows what the popups does (notice the CFD, SLD, LMD fields) .
[ATTACH=CONFIG]12382[/ATTACH]
I want to do the same exact thing for the popups in the search widget. So the end result is if I have the field turned on in the xml then those fields will be links as well. Here are three of the values that I am searching for as well as the urls I'm using.
var match:Array = htmlText.match(/^\s*((https?|ftp):\/\/\S+)\s*$/i);
var matchTwo:Array = htmlText.match("LMD 1");
var match3:Array = htmlText.match("LMD 2");
var match24:Array = htmlText.match("LMD 1, LMD 5");
if (match && match.length > 0)
     label = new mx.controls.Label();
     htmlText = '<a href="' + match[1] + '" target="_blank">' + match[1] + "</a>";
} else if (matchTwo && matchTwo.length > 0){
 htmlText = '<a href="http://www.cityofrc.us/cityhall/admin/gis/districts/landscape/1.asp" target="_blank">' + '<b>LMD 1</b>' + "</a>";
}else if (match3 && match3.length > 0){
 htmlText = '<a href="http://www.cityofrc.us/cityhall/admin/gis/districts/landscape/2.asp" target="_blank">' + '<b>LMD 2</b>' + "</a>";
}else if (match24 && match24.length > 0){
 htmlText = '<a href="http://www.cityofrc.us/cityhall/admin/gis/districts/landscape/1.asp" target="_blank">' + '<b>LMD 1</b>' + '</a>' + ' ' + '<a href="http://www.cityofrc.us/cityhall/admin/gis/districts/landscape/5.asp" target="_blank">' + '<b>LMD 5</b>' + "</a>";
I figured I would just show the code to make it easier. If it helps, one of the fields that contains these values is "LMD_NAME"
All possible values:
LMD 1
LMD 2
LMD 3A
LMD 3B
LMD 4-R
LMD 5
LMD 6-R
LMD 7
LMD 8
LMD 9
LMD 10
LMD 1, LMD 5
LMD 3A, LMD 3B
I'm sorry for the inconvenience, usually I can figure this stuff out myself without further instructions. Thank you for all of your help!
Isaiah,
  Well after looking into it deeper we can do all you need in just the PopUpRendererSkin.mxml. So here are the changes.
            override protected function commitProperties():void             {                 super.commitProperties();                  var featureLayer:FeatureLayer = hostComponent.featureLayer;                 var formattedAttributes:Object = hostComponent.formattedAttributes;                 var graphic:Graphic = hostComponent.graphic;                 var map:Map = hostComponent.map;                 var popUpInfo:PopUpInfo = hostComponent.popUpInfo;                 var validMediaInfos:Array = hostComponent.validPopUpMediaInfos;                 var geometry:Geometry = graphic ? graphic.geometry : null;                 var layerDetails:LayerDetails = featureLayer ? featureLayer.layerDetails : null;                  vGroup.removeAllElements();                 //vGroup.addElement(ToggleLayers);                 if (popUpInfo)                 {                     if (popUpInfo.title)                     {                         titleText.text = StringUtil.substitute(popUpInfo.title, formattedAttributes);                         if (titleText.text)                         {                             vGroup.addElement(titleText);                             vGroup.addElement(titleLine);                         }                     }                      var htmlText:String;                     if (popUpInfo.description)                     {                         htmlText = StringUtil.substitute(popUpInfo.description, formattedAttributes);                         if (htmlText)                         { //Code Addition                             htmlText = replaceIsaiahsContent(htmlText); //End Code Addition                             var descriptionText:Text = new PopUpText();                             descriptionText.percentWidth = 100;                             descriptionText.styleSheet = textStyleSheet;                                                          cleanAndSetHtmlText(descriptionText, htmlText);                             //trace(descriptionText.htmlText);                             vGroup.addElement(descriptionText);                         }                     }                     else                     {                         var descriptionForm:Form;                         for each (var fieldInfo:PopUpFieldInfo in popUpInfo.popUpFieldInfos)                         {                             if (fieldInfo.visible)                             {                                 var formItem:FormItem = new FormItem();                                 formItem.label = fieldInfo.label || fieldInfo.fieldName;        var label:Label;                                 htmlText = formattedAttributes[fieldInfo.fieldName];                                 if (htmlText)                                 {                                     // convert attribute field values that just contain URLs into links                                      var match:Array = htmlText.match(/^\s*((https?|ftp):\/\/\S+)\s*$/i);                                     if (match && match.length > 0)                                     {                                         label = new Label();                                         htmlText = '<a href="' + match[1] + '" target="_blank">' + match[1] + "</a>";                                     }                                     else                                     {                                         label = new PopUpText();                                     }                                     cleanAndSetHtmlText(label, htmlText);                                     label.selectable = true;                                     label.styleSheet = this.textStyleSheet;                                     label.width = 150;                                     formItem.addChild(label);                                 }                                 if (!descriptionForm)                                 {                                     descriptionForm = new Form();                                     descriptionForm.percentWidth = 100;                                     descriptionForm.horizontalScrollPolicy = ScrollPolicy.OFF;                                     descriptionForm.verticalScrollPolicy = ScrollPolicy.OFF;                                     descriptionForm.styleName = "formStyle";                                 }                                 descriptionForm.addChild(formItem);                             }                         }                         if (descriptionForm)                         {                             vGroup.addElement(descriptionForm);                         }                     }                      if (validMediaInfos && validMediaInfos.length > 0)                     {                         vGroup.addElement(mediaBrowser);                         mediaBrowser.attributes = graphic.attributes;                         mediaBrowser.formattedAttributes = formattedAttributes;                         mediaBrowser.popUpFieldInfos = popUpInfo.popUpFieldInfos;                         mediaBrowser.popUpMediaInfos = validMediaInfos;                     }                      if (popUpInfo.showAttachments && graphic && featureLayer                         && layerDetails && layerDetails.hasAttachments && layerDetails.objectIdField)                     {                         vGroup.addElement(attachmentInspector);                         attachmentInspector.showAttachments(graphic, featureLayer);                     }                      if (map && geometry)                     {                         vGroup.addElement(zoomToButton);                     }                 }             }  //Code Addition             private function replaceIsaiahsContent(content:String):String             {                 content = content.replace("LMD 1","<a href='http://www.cityofrc.us/cityhall/admin/gis/districts/landscape/1.asp' target='_blank'><b>LMD 1</b></a>");                 content = content.replace("LMD 2","<a href='http://www.cityofrc.us/cityhall/admin/gis/districts/landscape/2.asp' target='_blank'><b>LMD 2</b></a>");                 content = content.replace("LMD 1, LMD 5","<a href='http://www.cityofrc.us/cityhall/admin/gis/districts/landscape/1.asp' target='_blank'><b>LMD 1</b></a>");                 return content;             } //End Code Addition
IsaiahAguilera
Robert,
I have input your additions and it is now working beautifully! I still have to input the rest of my match fields but I don't see any problems coming up. I will let you know how it turns out. I really appreciate you taking the time to look into this further for me.
