Different symbols for separate results
4513
01-12-2015 09:41 AM
ShawnKraft
I have a tree inventory layer.  The arborist wants to be able to search for spruce trees with a hazard recommendation for removal.  He wants to see the results on the map.  He then wants to be able initiate another search for pine tree with the same hazard recommendation and have those show up on the map with different symbols.  The catch, he wants to see both results at the same time with different symbols.  Can this be done?
ShawnKraft
Perfect.  Thanks Anthony.
AnthonyGiles
Honored Contributor
Shawn,
Yes, you could add two separate search widgets into your application, just label them differently. Search spruce and search pine. i am not sure of the settings for symbology with the out of the box search widget as I don't use it, but Roberts esearch widget allows you to choose different symbology for each layer:
http://www.arcgis.com/home/item.html?id=5d4995ccdb99429185dfd8d8fb2a513e
ShawnKraft
