Custom Basemap for the Print Widget
1304
06-12-2014 11:52 AM
JonahWaterman
Hey I am still new to Flex and on a serious learning curve.
Here is the issue:
My organization has been using a utility template mxd  for external clients request to id our resources on a pdf but we want to improve the process and make this functionality within Flex available to the entire organization and not just the GIS people.
I have published all the layers  and customized the print widget so our template is an exact replica however when I hit the print function it will print to the ESRI basemap and I want to use our own symbology. So I published the desired basemap elements and their symbology to the server so I can just copy and paste the url into the basemap container within the Flex configuration code. However, for whatever reason the service I published will not display within the Flex map.  I have changed the type to "tiled", "dynamic", "feature" etc with no success. PLEASE PLEASE HELP.
I have attached images to further clarify the scenario. Thanks for your help
