com.esri.ags.symbol:SimpleMarkerSymbol or com.esri.ags.symbols:SimpleMarkerSymbol
1168
07-30-2012 10:31 AM
ShaningYu
Honored Contributor
In loading a project developed by a previous programmer, I received such a type of error.
Description Resource Path Location Type
component SimpleMarkerSymbol is defined more than once in this namespace.  Remove the mapping to com.esri.ags.symbol:SimpleMarkerSymbol or com.esri.ags.symbols:SimpleMarkerSymbol
Then I serached com.esri.ags.symbols:SimpleMarkerSymbol but did not find anything in the project.  How can I eliminate this error?  Thanks.
ShaningYu
Honored Contributor
RobertScheitlin__GISP
Shanning,
   Make sure you only have on AGS Flex API referenced or in your libs folder.
ShaningYu
Honored Contributor
Problems still exit.  In this project, I referred SDK 3.5B.  In the \lib\, there are only agslib-3.0-2012-06-6.swc and Json.swc
ShaningYu
Honored Contributor
