Change the selected symbol size in feature template
983
12-05-2012 05:57 AM
SaugatJoshi
Hi all,
I am using the editor tool to draw line in th application. However, when I draw the lines it appears to be really thick. The service I published for this has the size configured to be 1 pt, however ArcGIS 10.1 somehow defaults it to 6 pt for some reason. As a reson I was thinking to change the size of the graphics symbol when feature template is selected....however I am not able to get hold of the symbol size nor override it. In the Editor widget we have
case (Geometry.POLYLINE):       {        //var drawLineSymbol:Symbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, 0, 1, 1);        //var drawLineSymbol:Symbol = new SimpleLineSymbol();                        if (event.selectedTemplate.featureLayer.renderer != null)        {                  drawTool.lineSymbol = event.selectedTemplate.featureLayer.renderer.getSymbol(event.selectedTemplate.featureTemplate.prototype);        }        else if (event.selectedTemplate.featureLayer.symbol)        {         drawTool.lineSymbol = event.selectedTemplate.featureLayer.symbol;        }                drawTool.activate(DrawTool.POLYLINE);        break;       }
I was trying to get hold of drawTool.lineSymbol's width property like
drawTool.lineSymbol.width
. However I cannot get it. Is there any other way to do this. Thanks.
RobertScheitlin__GISP
Saugat,
The DrawTool.lineSymbol returns a Symbol and not a SimpleLineSymbol so you need to cast it to a SimplLineSymbol.
(DrawTool.lineSymbol as SimpleLineSymbol).width = 1;
Saugat,
SaugatJoshi
Thanks Robert, this fixed the problem.
