Can you add Map services name on Identify result?
990
04-23-2013 04:30 AM
MayJeff
I would like know that can you show map service name above layer results and only show one time if all layer results under the same map service when you use identify "all"?  Thank you.
RobertScheitlin__GISP
May Jeff,
   It would take me a good deal of time to direct you how to do this... It is definetly not as simple as adding a string some where. You would understand this if you were familiar with Item Renderers and DataGroups which this widget uses.
May Jeff,
   Sure it could be done but it would require you to do a lot of reworking of the code and the item renderer for the widget.
MayJeff
Can you give me some ideas where to start?  So if you just manually add a text will be easy right?
May Jeff,
