Can I change the checkbox message appearing on Templetepicker
1578
05-19-2011 11:22 AM
MikeCliffton
I want to change check box message appearing on Templetepicker in the Edit Widget.  Now there is a default layer called"Fires" on the Templete, if I uncheck the "Fires" layer, there will be information like"Fires feature layer is either not visible or out of scale range".  What if I need to change this message to others, such as "You unchecked the Fires layer"? Thanks!
BjornSvensson
Esri Alum
You can modify the text that shows up after the layer name using the configurable <featurelayernotvisibletext> label in the Edit widget configuration file.
"<featurelayernotvisibletext> - Label to display when a feature layer is not visible (default for English is "feature layer is either not visible or out of scale range")."
http://help.arcgis.com/en/webapps/flexviewer/help/index.html#/Edit_widget/01m30000000v000000/
MikeCliffton
thanks a lot!
