Basemaps not showing up consistently
629
11-15-2010 05:00 AM
CynthiaMatney
Hello.  I am new to Flex (and server).  I have downloaded the Flex Viewer uncompiled version.  For the most part I have set the map up the way I have wanted to and have added/changed widgets to meet my needs.  However, I am having an issue with my basemaps showing up consistently.
Basically I have created a transparency slider (with help) that should let me change my city's transparency level for it's imagery.  What I should see when I open my map is my street level basemap and then using the transparency slider I should be able to make my imagery show up.  I have had this working.  However, then I will run my map (from flex builder) again and then only the imagery shows up when it opens - the street map will only show up when I zoom in and the transparency bar won't work.
I have not changed anything as far as the basemaps go (these are called out in my config.xml file).  For instance this morning when I got to work it worked great...then I was in my header control mxml and then I reran my app and then suddenly I am back to just the imagery showing.
I don't know why this is happening.
Any help would be greatly appreciated!
Cynthia
