Autocomplete search box
4405
36
01-12-2011 04:13 AM
LemvigKommune
Hi.
I've just uploaded my AutocompleteSearch widget to arcgis.com - but
I would like it to iterate through multible url's and add the features in each url to the dropdownbox, but i can't get it to do just that.
If anybody has any idea as to how i could solve this, i'll be happy to hear about it.
Thanks
Mads Gren
AtifBashir
If this widget is affected by the maximum number of records returned by server, what is limitation of the number of records?
As I am not seeing all of my results in the drop down.
Thanks for any positive reply.
JasonNielsen
Under your Service you created on ARCGIS Server there is a spot that you can change the maximum number of records returned by the server. I think the default is like 1500. If you change this to the be greater than your number of records you can get everything back. Of course there is going to some delay before the autocomplete loads. Below is a picture on where you can find this setting.
[ATTACH=CONFIG]12095[/ATTACH]
Hope this help you in your problem.
ScottGaletka
I am trying to use the autocomplete search box and the search that comes out of the box with the Flex Application Builder. The auto complete search works great when i set my return values to over 16,000 records (roads and addresses) but my regular search is very slow to switch between records and zoom to. I tried to use separate internet services one for the regular search widget and one for the auto complete search but when i do that it places my zoom to record for autocomple to a place in the middle of the ocean in a different coordinate system.
http://www.bayfieldcounty.org/ArcGIS/rest/services (All my services)
http://www.bayfieldcounty.org/ArcGIS/rest/services/BFLRMapBasic/MapServer  (these are my basic layers, regular widget search)
http://www.bayfieldcounty.org/ArcGIS/rest/services/BFLRMapBuilding/MapServer/0 (This is my address search in the autocomple)
http://www.bayfieldcounty.org/ArcGIS/rest/services/BFLRMapRoads/MapServer/2 (This is my road search in the autocomplete)
when i use the above parameters the search sends me to a different coordinate system, seems the autocomplete does not account for different coordinate systems. But this seems a little faster.
and I have used this but is a lot slower:
http://www.bayfieldcounty.org/ArcGIS/rest/services/BFLRMapBasic/MapServer/3
http://www.bayfieldcounty.org/ArcGIS/rest/services/BFLRMapBasic/MapServer/0
Thank you
Scott
DaveKirkley
Is there a 2.5 version coming?
LemvigKommune
Hi Dave, I'v just installed the PreRelease version of server 10.1, and is looking at the FlexViewer 3.0 Beta, so i don'n know at this moment when i'll get the time to upgrade my code to 2.5, but when i'll look at it for the 3.0 i'll sure take the 2.5 into consideration.
Hi Scott, Strange problem, not one i've run into myself, but I think that I've read something about it somewhere, I'll try to find it and see if I can come up with some ideas.
Mads
HeenaLee
Mads,
I really want to use your auto complete search tool for the internal staff at work. I have 2.5 currently. I wouldn't upgrade to 3.0 until ArcGIS Server 10.1 comes out with SP1. Can I upgrade your 2.4 code to 2.5 in Flex Builder? What do I need to do? I appreciate your work! Please let me know. Thanks.
Heena Lee, GISP
GIS Coordinator
Village of Algonquin, IL
Email) hlee@algonquin.org
http://www.algonquin.org/gis
by Anonymous User
Not applicable
Mads, any update on the code for 3.0?
An autocomplete would be fantastic for our viewers ... 😄
RhettZufelt
MVP Notable Contributor
If you follow the directions in the readme file, the autocompletesearch seems to work just fine in 3.0 final.
You get a bunch of "no type declaration" warnings in the Flashcommander as component, but it doesn't seem to affect it as it works just fine.
R_
by Anonymous User
Not applicable
R_
Very cool ... I will have to check it out and see if it works.
MayJeff
The download page is not working:
http://www.arcgis.com/home/item.html?id=4a61e3e4b0c94300a3a361855d9a344f
Where Can I download the file?  Thank you.
