Attribute widget on top
3337
12-18-2012 03:16 PM
RhettZufelt
MVP Notable Contributor
I am trying to utilize the attribute widget, and when open, it opens over the top of all other widgets.
Is is possible to control which widgets it covers vs. draws under?
R_
HeatherGonzago
The widgetcontainer tag has attributes such as size, paneltype, and initialstate that you can configure.
E.g.
<widgetcontainer
paneltype="bottom" initialstate="open" height="250">
<widget label="Attribute Table" config="widgets/AttributeTable/AttributeTableWidget.xml"
url="widgets/AttributeTable/AttributeTableWidget.swf"/>
</widgetcontainer>
The paneltype allows bottom, left, or right.
Not doc'd, but you can also add the widget into a widgetcontainer similar to how your other widgets display.
 <widget label="attributes" left="430" top="90"
                icon="assets/images/i_table.png"
                url="widgets/AttributeTable/AttributeTableWidget.swf" />
Just like any of the other widgets, you can specify the layout of how the widgets will display relative to the application. http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Widget_Container_tag/01m3000000...
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Widget_tag/01m30000001w000000/
RhettZufelt
Thanks for the information.  However, it doesn't matter how I load it, it still opens above all other widget windows.  even if I open a widget afterwards, it puts it below the attribute table so it can't be seen.
I am trying to figure out how to make it open behind other widgets.
R_
SarthakDatt
Hey,
I just updated the default.xml to add the Attribute Table widget(not inside a separate widget container) and it behaves like any other widget. In the following screenshot, i opened the AT widget first followed by the GeoRSS widget, the GeoRSS widget is on top:
[ATTACH=CONFIG]20074[/ATTACH]
Here's the excerpt from config.xml:
<widgetcontainer layout="float">
        <widget label="Bookmarks"   left="430" top="90"
                icon="assets/images/i_bookmark.png"
                config="widgets/Bookmark/BookmarkWidget.xml"
                url="widgets/Bookmark/BookmarkWidget.swf"/>
        <widget label="Louisville Police" left="590" top="280"
                icon="assets/images/i_police.png"
                config="widgets/Query/QueryWidget_Louisville_PoliceStations.xml"
                url="widgets/Query/QueryWidget.swf"/>
        <widget label="Search" left="80" top="280"
                icon="assets/images/i_search.png"
                config="widgets/Search/SearchWidget_Louisville.xml"
                url="widgets/Search/SearchWidget.swf"/>
        <widget label="Earthquakes (GeoRSS)" left="410" top="280"
                icon="assets/images/i_rss.png"
                config="widgets/GeoRSS/GeoRSSWidget.xml"
                url="widgets/GeoRSS/GeoRSSWidget.swf"/>
        <widget label="Draw" left="60" top="400"
                icon="assets/images/i_draw2.png"
                config="widgets/Draw/DrawWidget.xml"
                url="widgets/Draw/DrawWidget.swf"/>
        <widget label="Print" left="390" top="400"
                icon="assets/images/i_print.png"
                config="widgets/Print/PrintWidget.xml"
                url="widgets/Print/PrintWidget.swf"/>
        <widget label="AttributeTable" left="390" top="400"
    </widgetcontainer>
Also, clicking on the header of a widget, should bring focus(move it to top).
RhettZufelt
Thanks Sarthak,
Taking your idea and playing with it some I see that the widgets can be moved above when open or by clicking the widget window IF that widget was in a widgetcontainer that opened after the other widgets.  So, if I move the attribute table to a widgetcontainer that loads first, all other widgets can be moved above/below by clicking.
However, I do like the "docked" to the bottom of the page option, and still see no way to make that "table" do anything but overlap on top of everything else.
R_
SarthakDatt
Yes, I can see how it can be an issue sometimes. If you make the 'docked' AT widget large enough either by dragging the orange panel bar or at startup. I tried the default config.xml again and looks like you can work around the issue(its an issue if the layout of the first widget container is 'float') by positioning your widgets:
[ATTACH=CONFIG]20080[/ATTACH]
config.xml:
        <widget label="My first widget"
                icon="assets/images/i_widget.png"
                config="widgets/Samples/HelloWorld/HelloWorldWidget.xml"
                url="widgets/Samples/HelloWorld/HelloWorldWidget.swf"/>
    </widgetcontainer>
    <widgetcontainer paneltype="bottom" initialstate="collapsed" height="250">
    </widgetcontainer>
This is using the default config-all.xml (horizontal layout):
[ATTACH=CONFIG]20079[/ATTACH]
