AttRelateInfoWinWidget and aliases
1204
02-22-2011 04:09 AM
CaussinDavid
Hi everybody,
I use without problem the widget AttRelateInfoWinWidget.
I use it for different layers (3)
For 2 of them no problem, but for the last one the aliases from the mxd are not shown ....
I could not understand why.
here is the code of the xml that don't work
<?xml version="1.0" ?>
<configuration>
    <fields>Nom_FR,Lien_url,Validite,Date_arr_1,Remarques</fields>
    <titlefield>Nom_FR</titlefield>
    <links>
     <linkfield icon_or_text_or_img="text" icon="" linkalias="Lien - Link" linkprefix="" linksuffix="">Lien_url</linkfield>
    </links>
    <datefields></datefields> <!-- field in milliseconds -->
    <zoomscale>5000</zoomscale>
    <csvseparator>,</csvseparator>
    <labels>
     <csvdefaultname>Related Records</csvdefaultname>
  <exportbtnlabel>Export...</exportbtnlabel>
  <export2csvoptionlabel>Export to CSV...</export2csvoptionlabel>
  <export2txtoptionlabel>Export to Txt...</export2txtoptionlabel>
    </labels>
</configuration>
Is it possible that the problem come from the mxd file??
Thanks in advance
CaussinDavid
If i add the <layername> tag it dont work ..... no field are displayed... 😞
RobertScheitlin__GISP
David,
   The layer name is definitely required. Are you entering the same name that is entered as the label of the layer in the main config.xml?
CaussinDavid
hi,  It was the problem .
I have search 4-5 hours Grrrrr
