Assign short cut keys to Map Controls - 508 compliance
1321
04-06-2011 07:42 AM
ParameswaranPalanivel
I am currently working in making the ArcGIS Viewer for Flex V1.3 508 Compliance. As part of the 508 compliance I am trying to assign short cut keys to map controls in the viewer. The viewer has toolbar with zoom in, zoom out,pan controls, and I am trying to assign short cut keys to access these controls. I am following "Accessibility Best Practices for flex" from adobe http://www.adobe.com/accessibility/products/flex/best_practices.html. Does anyone can help me ?
Thanks
Param.
BjornSvensson
Not sure if it may help you, but map navigation using keyboard is already supported for:
    * Pan using the arrow keys (keyboardNavigationEnabled).
    * Press the + key to zoom in at center of map (keyboardNavigationEnabled).
    * Press the - key to zoom out at center of map (keyboardNavigationEnabled).
http://resources.esri.com/help/9.3/arcgisserver/apis/flex/apiref/com/esri/ags/Map.html
Thanks Bjorn.
I want to launch identify widget, querybuilder widget etc., from the tools menu (attached image) using a short cut key without mouse. Is it possible ?
Thanks.
BjornSvensson
I want to launch identify widget... using a short cut key without mouse. Is it possible ?
Yes, it is possible.  But I'm not familiar enough with the SFV code to tell you where exactly to change actual code.
MarkHoyland
The link shows how it can be done in FlexViewer 2.2 by a configurable widget.
Not sure about ArcGIS Viewer for Flex V1.3, but it might give you some ideas.
http://forums.arcgis.com/threads/26526-open-a-widget-with-keyboard-shortcut?p=88389&viewfull=1#post8...
