When I click the supplied link to download the AppBuilder - I get a .zip file. Should the .zip be changed to .air?
...but I am still developing for 2.3.1. ...Please provide a link to at least the previous version (2.4) of the ArcGIS Viewer for Flex web pages.
There shouldn't be an AppBuilder-2.5.zip file. The file you download should be AppBuilder-2.5.air which you then either double-click (or right-click and "Install"). This will start the installation...Which OS and browser (and version) are you using? Maybe the browser for some reason does not recognize or keep the (air) file extension. Could you try downloading it from a different browser? Or rename your AppBuilder-2.5.zip to AppBuilder-2.5.air.
I just installed Adobe Air, dowloaded and unzipped the AppBuilder-2.5.zip file and tried to run AppBuilder.swf.
@Andrea,Are you trying to access the application builder, or an application created with the application builder?The application builder is an AIR application (not a web application, but more of a "desktop" application) and thus does not run in your web browser. It is accessed from the Start menu (or its non-English equivalent). You should not be copying AppBuilder.swf anywhere...
Sounds like you guys have missed the part where the Flex API is no longer included in the Flex Viewers source code due to the new Apache licensing. you need to download the API separately and copy it into the libs folder for your project.
The source code for the application builder is not yet available, but it is something we are planning for future release (that would support custom widgets, localization, widget groups, etc).
Will the application builder work with custom widgets? Or is there any change you can download the source code for the application builder?
