ArcGIS Online Feature Service and Related Records Issue
2597
11-17-2013 05:30 AM
by Anonymous User
Not applicable
Original User: cnorth
I'm Stumped...
I have created a feature service on my ArcGIS Online developer account.  The feature service has several layers, and two tables.  The two tables are related (via a relationship class) to two of the feature class layers.
The layers from the service display inside the Flex Viewer (3.5) no problem.  However, the info PopUps, and the attribute table always report "no related records" (screen shot attached).
I have verified through the REST end points that the related data is present.  I can go to the service directory for my ArcGIS Online service, and the "query related records" function is there, and works from the HTML page. Attached screen shots show my testing through the REST service seems to work.
I have tried the service with permissions set to "Everyone" and to my organization only - same result.
The same data worked when it was on my local development ArcGIS server just fine.
So, it seems like for whatever reason the Flex viewer (maybe the API?) does not recognize relationships when the service in in Arc GIS Online.
Has anyone else been able to get this to work?
Chris
SergioRodriguez1
I have the same issue, I create a feature service with 19 layers and 6 tables with relationships, when I query using the Viewer for Flex (3.6) "No related records" message display, but the same feature query with ArcMap work well.
When Esri plan to correct this problem,
Thank you.
