"Run Index" (debug) fails from Flash Builder/Firefox
3568
14
04-05-2011 08:59 AM
JayGeisen
Sometime recently, I cannot seem to debug in Firefox.  I'm thinking that maybe my version of Flash Player might be off or something.  Which version should I be using?  I have version 10 of the Active X and Plugin installed.
saurabhgupta2
Robert
Yes i have and i have and tested them . I am not sure if i have done it right or not but i have applied all these but still got the same result . May be im missing some piece ..
Regards
Saurabh
RobertScheitlin__GISP
Saurabh,
  Open a new question on this as this subject is pretty different and it would be good for people to find this question under a thread talking about setting up Flash build on a Windows 8 PC
saurabhgupta2
Robert
I have done it. Please find the below link
https://community.esri.com/message/400435#400435
Regards
Saurabh
saurabhgupta2
Robert
Can you help me finding right approach to some of the problems. I have been stuck with these from a long time ..
First is :
problem with adding dynamic featurelayer
Second is:
I have to do some task and I am not able to find how to proceed with it. Can u help me in this?
Task
1) A person with admin login logs into web application and then then edit a layer or 2
2) Those edited layer have to saved  and has to be shared for editing with some of people having different role .
3) Then they also submit the layer with changes and sends a notification to Admin about submitting of task
4) Admin people log into system and see the changes and save the final edited layer to main database.
Just wanted to know how we can proceed with this kinda task
Thanks in advance
Regards
JayGeisen
Thanks, Robert.  For the record, I fixed the issue I was having (temporarily, at least) by changing the Framework linkage (Properties->Flex Build Path->Library Path) from "Use SDK Default" to "Merged into code".  I'm not sure if that's ideal or not, as it makes the swf bigger, but that's the only way I can get it to debug now.
