after working on ArcGIS Viewer for Flex the map image got out of focus
2697
05-16-2014 01:41 AM
NatashaManzuiga
Hi, I have noticed that after working with some operation on the map service..like zoom, click, search, layer definition, the map is out of focus...like there is another layer over the map.. If I trace the network, I can get the url called to get the image from the ArcGIS Server...and if I run the link in another window of the browser I see that is pretty clear....the same image inside the viewer is totally out of focus...why??
Someone knows the problem?
Thanks in advance,
Naty
RobertScheitlin__GISP
Naty,
  What imageformat attribute do you have on your map service layer? If it is jpg than you should also set the dpi attribute as well.
NatashaManzuiga
Naty,
I'm trying with imageformat="png32"
but it seems like there is something strange in flash or viewer...cause the url called by the viewer show a clear image..
Naty,
   Hmm... Hard to visialize what you are talking about.
