adding footer to maps on 1.3 viewer
795
06-17-2011 05:09 AM
DanielLewis
I looked at the source to the 2.3 copyright widget by Robert Scheitlin and tried to make something similar for the 1.3 viewer, here's the source, which isn't working:
<?xml version="1.0" encoding="utf-8"?>
// Display footer on maps
<BaseWidget xmlns    ="com.esri.solutions.flexviewer.*"
      xmlns:mx   ="http://www.adobe.com/2006/mxml"
      x     ="600"
      y     ="220"
      widgetConfigLoaded ="init()">
 <mx:Script>
  <![CDATA[
   import com.esri.ags.events.ExtentEvent;
   import mx.controls.Alert;
   import com.esri.ags.Map;
   private function init():void
    map.addEventListener(ExtentEvent.EXTENT_CHANGE, repositionInfo);
    txtVersion.text = "footer text";
   private function repositionInfo(event:Event):void
 </mx:Script>
<mx:Label id="txtVersion" alpha="1" />
</BaseWidget>
And I added the following to the config.xml:
<widget right="95" bottom="3" url="com/xyz/widgets/footer/footer.swf"/>
Any help is greatly appreciated.
DanielLewis
I made some changes:
      x     ="600"
      y     ="220"
      widgetConfigLoaded ="init()" >
 <mx:Script>
  <![CDATA[
   import mx.messaging.channels.StreamingAMFChannel;
    const color:String = "0x000000";
    txtVersion.setStyle("color", toNumber(color.length ? color : "0x000000"));
    const fontFamily:String = "Verdana";
    txtVersion.setStyle("fontFamily", fontFamily.length ? fontFamily : "Verdana");
    const fontSize:String = configXML.label.@fontsize;
    txtVersion.setStyle("fontSize", parseInt(fontSize.length ? fontSize : "9"));
    const fontWeight:String = configXML.label.@fontweight;
    txtVersion.setStyle("fontWeight", fontWeight.length ? fontWeight : "bold");
    txtVersion.text = "Footer Text";
   private function toNumber(value:String):int
    if (value.substr(0, 2) == "0x")
     return parseInt(value, 16);
    return parseInt(value, 10);
 </mx:Script>
<mx:Label id="txtVersion" alpha="1"   text="Footer Text" enabled="true"/>
</BaseWidget>
Apologies to Robert for obliterating his code, but trying to learn.
This DOES display the text, but on the dock and it can't be undocked.  Perhaps I'm approaching this wrong and shouldn't do it as a widget?  Could a change be made to mapmanager (assuming that's the right place) to add a footer to the display below the map being displayed, or overlay the bottom of the map being displayed?
RobertScheitlin__GISP
Daniel,
  If you are wanting to add some static text to the bottom of the map then just add a mx label to the index.mxml.
DanielLewis
Daniel,
Thank you!  How do I make it so the label will "stick" to the bottom of the screen and move with the bottom edge as the user resizes the browser window?
Daniel,
   For that just set the bottom and right attributes to 0 or 5.
DanielLewis
Daniel,
Thank you again for your help.
