About the results grid of TOC
2221
06-24-2013 06:50 AM
LeiZhou
Is there any method that can control the length of the fields in the results grid? For example, when a field is a URL, the length is very long.  It will be great if the width of the column can be adjusted when showing up in the grid.  Currently, I think the results grid just read according to the original SDE database or map service.  So if I want to change the length of fields, I have to go to original database to change it.  Is there anyway I can do that in TOC widget or flex viewer directly? Thanks a lot!
