ArcGIS Video Server and Experience Builder
Question for the masses... We are looking to integrate Video Server into our on-prem Enterprise environment in the near future. We are curious to know if anyone has gotten the UDP streams to function within Experience Builder or any other internal app besides ArcGIS Excalibur. We want to be able to have a map in the center…
Video Server - Issue in GPU accessing
Hi Team, After successfully federating the Video Server with the Portal, I am facing an issue while trying to publish a video using ArcGIS Excalibur. The following error is displayed “A functional GPU was not detected on the registered ArcGIS Video Server. You can view published video services, but options to publish new…
Unable to publish video services when ArcGIS Data Store Object store is Default Item Storage
Hi all, I'm trying to publish video services from Excalibur to ArcGIS Video Server. When the default Item Store is configured on the File System, the hosted video layer publishes successfully. However, when I set the default Item Store to the ArcGIS Data Store, publishing the hosted video layer results in a generic error…
Livestream not available
I'm testing video server capability to consume rtsp streamed video from security webcam. Original url of webcam looks like rtsp://admin:123456@xyz.xyz.xyz.xyz:xyz/. Video server refuses to accept such a URL. HTTP response from browser network traffic says Input value rtsp://admin:123456@xyz.xyz.xyz.xyz:554 for parameter…
error creating layer
Hi I installed ArcGIS Video 11.4 server on Windows server 2025. I installed the WebAdaptor and opened the ports documented on the Esri site. when from Excalibur I try to run the example publication "https://learn.arcgis.com/en/projects/get-started-with-arcgis-video-server/" the upload happens but when creating the layer it…
What's New in ArcGIS Video Server (Nov 2024)
The November 2024 releases of ArcGIS include advancements that deliver a seamless imagery management and analysis experience across desktop, online, and enterprise environments to meet your growing organizational needs. In this release, we've improved compatibility with video sources such as GoPro, iPhone, and GPX files…
Attending #EsriUC2024 and want to learn how to use video in ArcGIS? Join these tech sessions.
Attending #EsriUC2024 and want to learn how to use video in ArcGIS? Join these tech sessions to explore how ArcGIS Video Server helps incorporate video into web-based remote inspection workflows in ArcGIS Excalibur and helps use drone imagery to enhance field operations. Or speak with our experts at the Motion Imagery…
ArcGIS Image Analyst and ArcGIS AllSource now supports video layers
We are excited to announce that ArcGIS Image Analyst and ArcGIS AllSource now supports video layers. When signed in to your Portal, you will see video layers as a data type in both the Add Data dialog and the Catalog pane and view. Through this new integration with Video Server, Image Analyst users can use the same…
ArcGIS Video Server support for RTSP live stream service with embedded username and password
I'm trying to publish the Video Stream Service using Excalibur. The setting that I enter when publishing: Protocol: RTSP Stream Address: username:password@IP Address/subdirectory/subdirectory Port Number: 9000 I've successfully published it, but the video layer is not available, and the stream service is stopped. is there…
Support 360° videos in ArcGIS Video Server
Based on discussions within the ArcGIS Community (Does or will Video Server support 360 videos? - Esri Community), I propose that ArcGIS Video Server support video-as-a-service published from 360° videos.
Enabling GPU for ArcGIS Video Server
I've installed the ArcGIS video server (ArcGIS Enterprise 11.2) within the NVIDIA GEFORCE GTX 1050 GPU environment. However, I'm unable to find the resolution option for uploading videos. How can I enable GPU for use with the ArcGIS video server?
Does or will Video Server support 360 videos? Any documentation or roadmap regarding this feature? I understand ArcGIS oriented imagery capability was introduced with ArcGIS Online 2023 October release (Map Viewer), ArcGIS Pro 3.2, and ArcGIS Enterprise 11.2 (Map Viewer and ArcGIS Excalibur). The support for 360 videos is…
How can I connect my drone to a livestream layer in ArcGIS Excalbur?
Hi! Has anyone successfully connected livestream equipment, such as a drone, to the livestream video layer in ArcGIS Excalibur?
ArcGIS Video Server with linearly referenced pipeline data?
Hi all Does ArcGIS Video Server also work with linearly referenced videos stemming from pipeline inspection done in water/wastewater pipes? If so, do I understand it correctly that, in addition to ArcGIS Video Server, there is always some form of client needed, i.e. ArcGIS Excalibur? Could a client for a partner solution…
Publish and Analyze Video Layers in ArcGIS Excalibur
With the release of ArcGIS Video Server, you can now publish and analyze ArcGIS Video Layers within ArcGIS Excalibur. ArcGIS Excalibur allows users to publish video files from various data sources as ArcGIS Video Layers and these layers can be consumed in Excalibur for further analysis. To go through a step-by-step…
Introducing ArcGIS Video Server
We're excited to introduce ArcGIS Video Server, a new server role for ArcGIS Enterprise that enables indexing, searching, publishing, and streaming video as a service with geospatial and temporal context. This new product pairs with ArcGIS Excalibur, a cloud-based imagery analysis application, where users can publish video…
