Support Publishing ArcGIS Velocity Outputs as OGC SensorThings API Endpoints
596
02-15-2026 11:40 PM
Status: Under Consideration
kntr
ArcGIS Velocity should support publishing real-time and analytic outputs as OGC SensorThings API endpoints. This would allow organizations to share IoT and real-time geospatial data using open standards and improve interoperability with external IoT platforms and open data ecosystems.
Many government and enterprise organizations are adopting open geospatial and IoT standards to support smart city, digital twin, and national data platform initiatives. OGC SensorThings API is widely used as a standard interface for IoT sensor data exchange.
Currently, ArcGIS Velocity supports strong real-time ingestion and analytics capabilities, but does not natively support publishing outputs using SensorThings API. Organizations that require this must build custom middleware to translate Velocity outputs into SensorThings format.
Example Use Cases
  • Smart city sensor data sharing (traffic, environmental sensors)
  • National environmental monitoring platforms
  • Utility infrastructure monitoring across multi-vendor systems
  • Open IoT data portals
2 Comments
PeterNasuti
Thanks @kntr for this idea - we have already been discussing and looking into OGC SensorThings support as a feed type. It's under consideration at this time.
For an output, Velocity would likely take the initial approach of supporting POSTing to an existing OGC SensorThings server API. We can further explore the feasibility of extending ArcGIS Velocity to function as an OGC SensorThings API for downstream client consumption as well.
If you can provide samples or API access to the OGC SensorThings data you are working with, we can incorporate that into feature design and testing.
kntr
Many thanks for the update @PeterNasuti. I look forward to seeing new, exciting updates to Velocity in future releases. I will try to find a sample API and get back to you with updates.
Cheers,
Kanin
