What have others done concerning transformers and phase propagation?
1559
09-12-2022 07:15 AM
G_Dillenger
We have many 3 phase complex edges with single phase transformers on the vertexes in the middle and at the end of these complex edges. I say complex edge since that is what the geometric network called them, now that is Edge Policy of Any_Vertex in the utility network.
After a bit of testing I have concluded 4 options:
  1. Set Subnetwork Tap to the transformer while sacrificing terminals and the inability to place them at the end of the line. An option could be to create a second transformer type to connect at the end of a line. 1st; T-tap and 2nd; T-terminal.
  2. Give the transformer terminals while sacrificing our complex edges and tapping. This means we have to split each line from transformer to transformer. Without terminals the phase is filtered out downstream.
  3. Create 3 separate lines for each phase that will not require me to use terminals nor taps on the transformers.
  4. Offset the transformer and create a junction at its previous x,y location. I will need to create a junction-junction association. This is at the sacrifice of keeping my transformers in the current x,y location. This impacts visualization that we are used to. Assemblies could be created here in the stead but then I have to select by association to get the transformer information plus I have to configure another association with containment. This could result in a 2x or 3x more features that we currently have.
Our preference is option 2, since we can control the splitting and update lengths. However, I feel this is at a big cost since with this option many new segments will need to be maintained. One of the reasons for keeping transformers on the lines is simpler for my integrations that require a spatial location.
What have others done in this situation?  Any other suggestions I missed?
RichardKoch
We battled some of these same issues and we already have the offset geometry for our units. a few things to note.
  • Assemblies do not participate in the UN like the actual units do. They are simply containers.
  • Terminals may help using the propagator that comes with the UN but the are a downstream workflow load for maintaining the system going forward. Translation on that is installing new units becomes more click intensive depending on how your new units come into the system. Not all work design systems support terminals so you may end up with a semi custom solution that you have to manually check prior to validation/reconcile.
  • We decided to disable propagation and use the batch trace updater at the link here.
Utility Data Management Support Tools - February 2022 Update (esri.com)
I hope this helps some.
Richard Koch
G_Dillenger
Appreciate the comment! I recall reading the blog but apparently the Batch Trace missed my application appeal. I will have to give it a try.
