Hello, we came across this error when using the task come with UN water solution. Right now we are using file geodatabase. Wondering what's the problem here?
Can you post a picture of the layers in your TOC? I uploaded a newer version of the tool that might solve your issue.
I can change the data source one by one. But I found that sometimes I can change the data source for one layer and the others automatically follow. sometimes it doesn't allow me to change the source of dataCapture1.PNG
I deleted the map and recreated a copy. now when I change the data source for water device layer, all other items are automatically switched to new data source. Thanks for the updated tool. will save it for future use. Cheers,
Song
