Naperville Demos in FIle Geodatabase?
2100
02-17-2021 11:02 AM
SSMIC3038
Can the Naperville demo asset packages be generated in a file geodatabase?
Or do UN's have to be built from scratch in file geodatabases?
by Anonymous User
Not applicable
Hey Craig,
Yes, they can be applied to a UN in a file gdb.  The latest solution has a task in the project that will walk you through the process or you can just build a file gdb stage it then apply asset package with Naperville data.
https://doc.arcgis.com/en/arcgis-solutions/reference/introduction-to-water-distribution-data-managem...
by Anonymous User
Not applicable
Hey Craig,
SSMIC3038
Works, thank you!
