I imported a list of junction-edge connectivity associations into an electric UN with "import associations" tbx.
For purpose of simplicity, all junctions are associated with the "from" rule (I guess it means the first vertex of the line).
Thus, after successful import, I have several junctions associated with the same first vertex of a line. When I try to validate the topology, I now have errors on the lines :
| Error(s) | 21: Duplicate vertices. |
I tried to reproduce manually, but it is not permitted to associate more than one junction at the same end of a line :
Is there a way to get rid of this restriction and have multiple junctions connected to the same line at the same vertex ? Or I have to create midspan associations and set a random value...
Another question is, when I try to view these associations, nothing appears on the map (no dashed line like an association between to points), is this the normal behaviour ?
