manhole as in the structure junction and it also gets added in the sewer device
666
07-17-2024 11:01 PM
Angiex__1
The manhole when we match it gets the structure junction, but we have the attribute rules where the manhole gets in the sewer device too. But how do I make the manhole in the structure junction attributes be copied in the sewer device too? because i have so much fields in the structure junction for the manhole, how do i let the same fields get to the sewer device too when the attribute rule works.
MikeMillerGIS
Esri Frequent Contributor
take a look at the Update Related tool in this toolbox.  It will generate the Attribute rule for you
https://github.com/Esri/arcade-expressions/blob/master/attribute_assistant/AttributeAssistant.atbx
