Inconsistent trace results
4333
11
11-23-2022 06:53 AM
Jens_Dalsgaard
I experience inexplicable and inconsistent downstream trace results. I have really tried myself understanding what is going on - I do not get it though.
From a high voltage substation (HV/MV) I set a trace start flag on the secondary winding on one of the transformers and request a downstream trace - se screen dump below:
As the trace is set to continue into low voltage (target tier), of course I would expect the trace to do so. In the below screen dump, you see that it does not continue into the low voltage mesh (blue lines):
And zooming into a medium voltage substation (MV/LV) it is clear that the trace stops at the MV/LV transformer - se screen shot below:
Really strange, cause I have successfully run an update subnetworks on the low voltage mesh, so I know that the trace from this transformer and downstream should work.
Now, moving the trace start point (from the HV/MV transformer secondary) to just outside this substation and running the exact same trace I reach this inconsistent result that you see below - the trace continuing through the MV/LV transformer and into the low voltage mesh as configured in the GP:
Enlighten me please, Esri (or someone else). I cannot see me doing anything wrong here - I might though. Or UN might have a bug?
One thing is for sure - you have a puzzled user.
Jens Dalsgaard
Principal Product Owner
Power Grid, V O L U E
jens.dalsgaard&@volue.com
Volue Technology Denmark A/S
Alfred Nobels Vej 27
9220 Aalborg Øst, Denmark
volue.com
MikeMillerGIS
Esri Frequent Contributor
Jens,
  This appears to be BUG-000148077 - Downstream trace does not traverse all adjacent subnetworks across tiers.
GIS_Solutions
Hi
Are you using the asset pack made by esri electric foundation?
Can you add a screenshot of the all tier and terminal configuration?
Jens_Dalsgaard
We're using the UNC data model from the Utility Network Community. John Alsup / Mike Miller know it.
I will send information about tiers and terminals tomorrow.
Jens Dalsgaard
volue.com
Jens_Dalsgaard
Please find the requested information enclosed.
Jens Dalsgaard
volue.com
Jens_Dalsgaard
By the way - allow me to mention that performing a similar downstream trace from the HV/MV transformer in a migration from a different source using the exact same asset package template the trace propagates nicely into the low voltage mesh.
Hence, I doubt it has anything to do with the schema / data model configuration.
Jens Dalsgaard
volue.com
MikeMillerGIS
Jens,
Jens_Dalsgaard
OK, thanks for the feedback, Mike.
Where may I read more on this bug, and what is the priority / time-frame on fixing it?
Jens Dalsgaard
volue.com
MikeMillerGIS
It does not appear this bug is exported to the our web system.  Best option would be to log a support incident and get yourself added to this issue.  The more users affected increases it priority.
Jens_Dalsgaard
Will do so through the Elvia Premium Support (as it is related to / documented on Elvia UN data).
Thanks for feedback, Mike.
Jens Dalsgaard
volue.com
emin-saka
Hi, @Jens_Dalsgaard
I got the good news from the esri UN team. This bug (BUG-000148077) will be fixed in the next version 3.2
Thanks  for your concern and support,   @Remi_Myers
