When I open the Error Inspector from the UN tab and I select an error and try to zoom to it, nothing happens, The map view doesn't change.
Any ideas why this might be?
Hanlie
Yeah, well.
I have found that selecting an error in the Error Inspector it will select the corresponding record in the dirty areas class. If you open the Dirty Areas table, you may then zoom to the error from here. Or from the standard Zoom To buttons.
Seems like a bug - just never bothered to log it
Yeah, well.
@Jens_Dalsgaard Please log an issue 😉
Oh, too lazy. Or - the work-around is too simple for me to bother 😉
Thanks, this sounds like a good workaround for now.
