I have a Problem on the ArcGIS Utility Network. I have managed to apply asset package of essential model to my Enterprise Geodatabase. I have enabled database to use Branch version both on database level and dataset level, i have also enabled Network topology but the issue is that in the ArcGIS Pro before publishing i can not be able to use any of Utility Network tools, they are all disabled when based in database connection and then i tried to publish UN web layer but still i got a challenge of not getting traces and Utility network functionaries either in experience builder and in web editor.
I need your help on the best workflow step by step to publish UN successfully and being able to access it and use it in ArcGIS Web Editor. Thank you
