Hello
which method is usable to integrate data between GIS data and power factory ?
We are using a CIM adaptor for Utility Network to PowerFactory
@AnthonyRyanEQL Thanks for ur reply . Does it work great ,without any problems ? So Could we exchange data between power factory to GIS or from GIs to power factory ? Could you explain some more about it ,advantages and disadvantages?
How long it takes approximately to export the whole GIS data then import them into Power factory ?
It's only 1 way comms from Utility Network to PowerFactory. It's a 3rd party tool we purchased from Similix (Esri Partner). Basically, there are 2 parts, the Designer (CIM mappings) and the Adaptor.
Designer - You build your mappings from your UtilityNetwork Model. This can be a lot of work depending on how custom your UNM is. In my case, our UNM is totally custom as the North American electrical model of UNM doesn't meet the needs here in Australia.
Adaptor - Runs as a service connecting to your UtilityNetwork. It uses OOTB REST API calls to the UN to extract the subnetwork information and maps it accordingly to your CIM mapping file into the standard XML format to be consumed into PowerFactory.
Sorry I can't tell you how it works inside of PowerFactory.
Thanks a lot ,it is a good start for me .
CIM based extracts from UN to PowerFactory works and is already in play at Denmark's second largest DSO feeding approximately 40% of the Danish land base and 800.000 meter points.
As an alternative to the above suggested product, Volue offers our SaaS based UN CIM Extractor allowing you to export any section of your grid based on UN traces: https://www.volue.com/products-and-services/grid-planner.
Plugs right into PowerFactoryReach out if interested
Hello,where did you find the documentation on the format expected by Power Factory? It seems to be an RDF (XML) format based on the CGMES standard, but quite different from, say, an ADMS schema with several files for the equipment, the topology, etc.
@PierreloupDucroix - I didn't find documentation for CIM specifically but here is the DGS manual. This is good for understanding the structure ElmTerms, StaCubics, etc. I have also attached the rdfs files in CIM folder along with some other material that was supplied. We ditched the CIM/CGMES method for GIS->FME->Excel (DGS format). This excel file is imported into PF.
