Hey, me and my friend are trying to recreate ESRIS Utility Network: https://learn.arcgis.com/de/projects/validate-edits-in-the-utility-network-with-attribute-rules/
It is using Subytpe Group Layers and still has domains for each Subtype. However we are unable to duplicate that. Our assettype remains empty. When you take a look into the esri projects domains their assettype is empty even though you are able to select assettypes in the attribute table. That doesnt make sence to us. And we have no idea where those are coming from.
We would be thankful for any tips.
Thanks in advance Fynn 🙂
Hey Heidi, no that's not it. We are not searching for the basic "how to assign specific asset types domains for each". We are trying to rebuild the utility network above to find out how to set up subtypes and domains while Subytpe Group Layers are activated. I'm trying to explain in more detail in the following...
Someone set Lucas's Question on solved even though it wasn't...sad.
Hi @FynnScharpen,
I hope i did not misunderstand you. If you want to group layer. You need to call the data under the add preset tool. and then you can apply symbology to the feature class by asset typr or asset group.
You can call data by following the screensshoots.
Good Morning, no that's not it . I know how to set up Group Layers and I know how to setup new domains 😞
oh im Sorry,
Maybe You can detail your problem with a few screenshots. we can better understand the problem
What we are trying to recreate is:
For Devices --> We wanna have 3 asset groups with their own attribute table (1,2,3) and each shall have 3 asset types with different symbology like in the project https://learn.arcgis.com/de/projects/validate-edits-in-the-utility-network-with-attribute-rules/
Before we used the traditional way WITHOUT Subytpe Group Layers then you have all assetgroups in one attribute table and can only set one symbology for each asset group...that's not what we want.
