How can I set selection-based visibility range
2265
11-15-2022 12:56 AM
GIS_Solutions
I have features with the visibility set to appear at 1/1000 scale.
I want the selected features to be displayed on the map regardless of scale as a result of a trace analysis.
How can I display the details in the trace results on a scale-independent map?  How can I do that?
Jens_Dalsgaard
If what you need is to visualize the trace result at a higher scale, ask yourself if you actually need to show the features at this higher scale.
If not, the answer to your need may be to simply output the trace result as Aggregated Lines - a graphic element built with the geometries of the trace result.
Such graphic element will not be turned off a higher scales (unless you actually do something to make the do so).
Jens Dalsgaard
Principal Product Owner
Power Grid, V O L U E
jens.dalsgaard&@volue.com
Volue Technology Denmark A/S
Alfred Nobels Vej 27
9220 Aalborg Øst, Denmark
volue.com
emin-saka
I think that @GISSolutions is right.
ArcGis Pro product team can add to main settings an option “show selected features/objects of layers on the map under all conditions (even if the scale is set)
Very simple suggestion
RobertKrisher
One of the things I've done in the past to work around this is to create a selection layer (or layers). You can learn more about selection layers here: https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/selection-layers.htm .
emin-saka
Hi @RobertKrisher ,
Your suggestion is good thank you however Once we using the UN with the subtype group layer, the option is disabled.
so which was suggested (“show selected features/objects of layers on the map under all conditions (even if the scale is set)") can be helpfull for UN users.
Bili
Maybe mark as highlighted so you can see even when the layer is inactive
