Enable topology failing: Error 001992 data set must be versioned
3559
12
02-26-2020 03:05 PM
JasonVignochi
Hi, I have asked a question about topology in the UN but may have put it in the wrong category to get the correct views. I would appreciate any help or insight as to why the Enable Topology tool is not recognizing my dataset is versioned, even though it is definitely versioned.
https://community.esri.com/thread/248907-enable-network-topology-fails-citing-need-for-versioned-db-...
GIS_DEV3
We're you able to resolve this issue?
AbhinovDutta
I had the same issue. Initially, I simply right-clicked the dataset > Manage > checked Versioning, but that didn’t work. I then ran the 'Register as Versioned' tool for the dataset, which solved the issue.
GurkanTurhal
Hi @AbhinovDutta,
We had the same issue. If you still have the same issue, you could run register as versioned geoprocessing tools for dataset in database, after that process will solve your issue. I hope it will work.
