I notice that the "Rated Power" field uses a domain containing kVA (apparent power) values instead of kW (actual power) values. I find this slightly odd because generator manufacturer spec sheets more often contain KW rather than kVA values.
I could not find a field in low voltage generation to store my generators' KW values.
Is my best course of action to convert my KW values to kVA?
Thank you.
