Change default value field and domain of fields mantained by UtilityNetwork
596
01-09-2023 07:41 AM
geopamplona
I am trying to change default values of fields maintained by the UN.
Could change "unknown" to another word in my language ? for example "desconocido" ?
On the other hand, could change description of domains maintained by the UN, for example Network_IsConnected ??
Can values be translated, using the D_Rename table?
Thanks !
JohnAlsup
D_Rename will allow to change domain descriptions of domains not managed by the utility network, this would include domains that are included in the Solutions Foundation models.  When you generate the D_Rename table (or use the existing one) no UN managed domain descriptions are currently added to the list of values.  However, you cannot change the UN managed domain descriptions at this time.
If you need or want the capability to rename UN managed domain descriptions (and I do) please enter an enhancement request for esri technical support.
John Alsup
jalsup@esri.com
JohnAlsup
John Alsup
jalsup@esri.com
