This tool works if I choose keep it all. Any combo of other settings does not work. I made a new clone and reinstalled the UN Tools package. I've attached the empty AP.
Start Time: Friday, September 6, 2024 8:40:44 AM
ArcGIS Pro 3.3.1.52636
untools 3.3.2
Executing from ArcGIS Pro, 14 map(s), activeMap = False
Parallel processing enabled: 6
Asset Package schema version: 2.9
A python error occurred.
EXCEPTION
File "C:\Users\bmay\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\untools\common\wrappers.py", line 161, in wrapper
f = func(*args, **kwargs)
File "C:\Users\bmay\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\untools\gptools\tools.py", line 270, in run
ap = ap_constructor(
File "C:\Users\bmay\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\untools\gptools\tools.py", line 90, in ap_constructor
ap = AssetPackage(
File "C:\Users\bmay\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\untools\utility_network\ap.py", line 93, in __init__
EvaluateConfiguration(self, configurations).main()
File "C:\Users\bmay\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\untools\utility_network\configure.py", line 1216, in main
self.fix_xml()
File "C:\Users\bmay\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\untools\utility_network\configure.py", line 1167, in fix_xml
self.un_items = self._collect_asset_groups_types(lookup)
File "C:\Users\bmay\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\untools\utility_network\configure.py", line 668, in _collect_asset_groups_types
asset_type_domains.add(asset_group.asset_type_domain.name.casefold())
File "C:\Users\bmay\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\untools\common\wrappers.py", line 414, in wrapper
return func(*args, **kwargs)
File "C:\Users\bmay\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\untools\describe\controllers\utility_network.py", line 353, in asset_type_domain
return self.parent.table.subtypes.get_id(self.code).fields.get("AssetType").domain
AttributeError: 'NoneType' object has no attribute 'fields'Failed script Asset Package To Geodatabase...
Failed to execute (AssetPackageToFileGeodatabase).
Failed at Friday, September 6, 2024 8:41:20 AM (Elapsed Time: 35.70 seconds)
