ArcGIS Solutions 2024 Product Roadmap - Electric Utility Network Foundation
1563
11-29-2023 09:20 AM
AJ_GeoPro
@RobertKrisher @JohnAlsup
In the September blogpost "ArcGIS Solutions 2023 Product Roadmap" the Electric Utility Network Foundation Solution was not listed under the Mid-term (Q1 2024) or (Q2 2024).
Is there an estimate for the next UN Foundation Version release?
Will there be backwards compatibility between Enterprise 11.2, Pro 3.2 and the existing UN Foundation v2.2? Will the next UN Foundation version be structured to leverage the changes in the "Enhanced Data Storage with Four New Field Data Types"?
Utility network compatibility
Thanks in advance for any information that can be shared.
MikeMillerGIS
Esri Frequent Contributor
At the moment, we do not have an update planned for the Electric Utility Network Foundation.  The solution is forward compatible and will support 11.3/3.3.  You will be able to take advantage of the new field types when they are supported in the Utility Network.
Are there other features you are looking for?
MikeMillerGIS
AJ_GeoPro
Thank you for your reply @MikeMillerGIS
I was just trying to see if there might be any big changes coming up that could affect our current plans, without any specific features in mind.
