ArcGIS Pro 2.7.2: Deleting a feature from “utility networks” gets the Pro to crash,
I couldn’t figure out why deleting a feature from “utility networks” gets the Pro to crash
The data and aprx file are attached
@JamalNUMAN I would recommend creating a case with Support to review and determine if the issue you are encountering is reproducible and related to the defect you referenced or something else that the team needs to investigate.
As per the screenshot below, just select feature #3 in the water line layer and delete it. This should cause the Pro (2.7.2) to crash!
Are you just deleting the UN dataset from the feature dataset and receiving a crash?
If so, this is different than the bug you are including in your screen captures as they are deleting domains.
I cannot reproduce the crash with your UN provided in the zip file, but I am using ArcGIS Pro 2.8.
1. What if you delete the UN at the feature dataset level?
2. Are you able to reproduce this crash with any FGDB UN that has certain domains configured or is it specific to your FGDB dataset?
This issue is occurring with file geodatabase that have coded domain (no versioning is included)
did you try in the Alternate Solution which also means this is what to do if you aren't doing something right
It also said it wasn't reproducable and
Not in Current Product Plan
Then this bug persists to exist in 2.7.2 as per the data provided
You should check the Esri Support Home for more
Esri Support | ArcGIS Technical Support
eg
BUG-000115367: ArcGIS Pro crashes when deleting, adding, and editin.. (esri.com)
