ArcGIS Pro 2.5: The “disable network topology” tool gets the software crashed,
3778
13
06-14-2020 11:24 AM
JamalNUMAN
Legendary Contributor
I observed that each time the “disable network topology” tool is performed then the software gets crashed.
Is this a documented bug?
Jamal Numan
DanPatterson
MVP Esteemed Contributor
5 bugs
https://support.esri.com/en/Search-Results#search?q=disable%20network%20topology&content-type=Bugs
check out their numbers and see what else it might impact in your workflow
... sort of retired...
WillBooth1
Hi Jamal,
The “disable network topology” fails in ArcGIS Pro 2.5.1 using your data, so the work around is either to download the latest 2.6 beta and install it somewhere else (as it is unlikely to be as reliable as 2.5.x for general use) or upgrade to 2.6 when it is available.
Cheers
Will
JamalNUMAN
Many thanks for the feedback
I’ll be doing my best in order to try it on the 2.6 Beta and find out if this bug is resolved
Jamal Numan
MajdoleenO_A__Awadallah
It seems that this issue is solved using Arcgis Pro  2.6.0 Beta.
Best
Majdoleen
