Any way to bulk delete associations?
1811
06-24-2022 06:44 AM
ZachLawlor
We are currently setting up a Un and are having issues with bulk deleting associations. There are roughly 90,000 associations that need to be removed, but I cannot find an easy way to do this in bulk. You can export and import attachments, but not remove. Any help would be appreciated!
GIS_Solutions
Maybe you can try to remove the associations using the content below with attribute rules. I think a button should be added to the Modify associations panel to remove associations in bulk.
https://www.esri.com/arcgis-blog/products/utility-network/electric-gas/advanced-attribute-rules-crea...
GIS_Solutions
ZachLawlor
Thanks, I'll give this a try to see if it works!
