““Add tier” tool to a utility network is not working as expected and ends up with an error”
632
12-22-2019 12:07 AM
AlaaFlaifel
"Add tier" tool to a utility network is not working as expected and ends up with an error
Please check the screenshot below.
What could be the issue here?
MelissaJarman
I am wondering if your utility network datasets contain data? Currently, the Add Tier process is expected to be completed during the initial configuration stage. This is due to the process adding a not nullable field to certain network datasets. You cannot add a not nullable field to a dataset that contains rows/data.
We are tracking an enhancement to make a change in the implementation for a future release.
Workflow topic on adding a tier: Define a tier—ArcGIS Pro | ArcGIS Desktop
Geoprocessing tool: Add Tier—Utility Network Toolbox | ArcGIS Desktop
TJ_Houle
Hi there! I'm wondering if you might have an update on this issue. Has the enhancement been released?
Thank you!
she/her/hers
