This Slide deck contains information to help understand essential utility network concepts that we are used in the Solutions Electric Foundation model. This is the second in our series of documents related to the Esri Electric Utility Network Foundation model.
Thanks @JohnAlsup . Please comment below if you find this type of post valuable here in the Esri Community.
I think it's super valuable! Great content - thanks for including the notes in the download.
Thank you @JohnAlsup this is fantastic!!
Great info, thanks for share.
Thanks for pointing to these documents at IMGIS23, very much appreciated.
Great Info these attached document. Its very much appreciated
Thanks so much @JohnAlsup.
Hi John. About network attributes, specifically device status... What if I swap codes between open and close?
I have a case when geometric network has 0 assigned to open and 1 to close. But your document defines 0 to close and 1 to open.
I fear if I use the geometric network definition, utility network will misunderstand it and will occur topological errors by wrong connecctions.
Could you help me?
You would need to update all the subnetwork definitions and any stored traces and change the descriptions in multiple domains.
