Utility Network tools deprecation in ArcGIS Online
2373
11-13-2024 01:08 PM
AlixVezina
Deprecation Notice
With the November 2024 update of ArcGIS Online, utility network tools are now deprecated in all apps and will not be supported in future releases of ArcGIS Online. Utility Network tools remain available in ArcGIS Enterprise and Developer SDKs.
Why? – Security concerns and the need for offline support limits most utilities from sharing their utility network data publicly. While utility network services can be shared in ArcGIS Online through a proxied service, this setup is incompatible with utility network tools.
About the Utility Network tools
These tools, sourced from the ArcGIS Maps SDK for JavaScript, can be found across different apps in the ArcGIS platform.
What to expect after November 2024
Utility Network tools remain available in ArcGIS Enterprise and in Developer SDKs. This deprecation notice only affects your apps in ArcGIS Online. Here’s what you can expect after the November 2024 update:
  • Experience Builder: The Utility Network Trace widget is no longer available in the Insert widget pane and cannot be added to new applications. A deprecation notice is displayed in the builder. The widget is still available and still works in your existing apps.
  • Instant Apps Sidebar template: A deprecation notice is displayed when configuring an app with the Utility Network Trace tool. The tool is still available and still works in your existing apps.
  • Map Viewer: Utility Network tools are no longer available in ArcGIS Online Map Viewer.
  • Web Editor: Utility Network tools are no longer available in ArcGIS Online Web Editor.
Note: Version management tools will remain available in ArcGIS Online but do not work with proxied services.
What’s next?
In an upcoming release, the Utility Network Trace widget will be removed from all existing Instant Apps and Experience Builder apps in ArcGIS Online.
If you’ve built apps with the Utility Network Trace widget in ArcGIS Online, it is recommended to remove the widget from your apps.
3 Comments
Contributors
About the Author
Alix is a senior product engineer on Esri's ArcGIS Solutions Web Development team, where she delivers innovative web mapping tools for various industries. She's passionate about customer success and combines her knowledge and experience to help solve problems and empower others to develop impactful applications that provide essential functionality.
