will the feature service be deleted if I change a text box size?
1501
5
11-07-2016 08:39 AM
DanielCruz1
Hi, I have a feature service up an running but I need to update a couple of text boxes by making them a bigger size, will my exiting records be deleted? thanks
JamesTedrick
Esri Esteemed Contributor
Hi Daniel,
Changing the appearance of a text question to multiline will not affect existing data.  Early (beta) versions of Survey123 Connect did delete data on all republishing; if you get a warning message about data being deleted, please download the latest version of Survey123 Connect.
DanielCruz1
I am not changing any changes from text to multiline, am trying to increase the size of a text box, can I do it without affecting my feature service?
JamesTedrick
Yes, you can do that without affecting the feature service using Survey123 Connect.  The particular change you need to do to make the text boxes bigger is to give those questions the appearance multiline.
DanielCruz1
Thanks, I just need 6 more spaces in this box for email addresses.
IsmaelChivite
Esri Notable Contributor
Hi. This help topic describes in detail the type of changes in a survey that will force the feature service to be re-created, versus the changes that will not, Publish your survey—Survey123 for ArcGIS | ArcGIS
