Why do Feature report maps not work if they contain WMS layers?
1490
05-27-2020 07:23 AM
RABConsultants
I am building a new Survey and a set of custom feature report templates. As part of the report i would like to use a webmap from my AGOL account to help show the risk from surface water to the particular property. I have the web map saved within my account. The surface water data is accessed via 3 WMS layers from the UK Government. In the feature report I call the webmap using the following:
${Surfacewatermap | mapSettings: “4bbbf59a6a37459890c0b21ade55ecc2”:5000 | size:600:500}
However, when running the report it will always time out with the following error
Failed to print map for ${Surfacewatermap|mapSettings:"4bbbf59a6a37459890c0b21ade55ecc2":5000|size:600:500}. waiting for function failed: timeout 180000ms exceeded
I can create the map without issues if i upload the surface water data as a vector tile layer and save as a new web map. But that would result in frequently having to update the map as the data is reissued every so often. Is there something i can do to get WMS layers to work?
thanks
RABConsultants
Still unable to solve this, has anyone had similar experiences?
JamesTedrick
Esri Esteemed Contributor
Hello,
Apologies for the delay in response.  In testing, I am not seeing the presence of a WMS layer causing timeouts in the generation of a report.  It may be there is something particular to the WMS service you are using?  Could you open an Esri Support ticket to work on troubleshooting this issue?
RABConsultants
Hi James,
I have submitted the ticket and will update this if a fix is found in case it is useful for others
Rob
