What the best way is to back up Survey123 built in Connect (before reformatting a computer)
1151
10-27-2022 02:28 PM
RyanBohan
Wonder what the best way is to back up Survey123 built in Connect (before reformatting a computer)
I have a copy of the entire folder containing the .xlsx files for the surveys.  I assume they won't likely just be able to be dropped into the rebuilt computer.  At the very least I can copy the old logic
Copied folder:
C:\Users\<username>\ArcGIS\My Survey Designs
Thank you
DougBrowning
MVP Esteemed Contributor
Actually you can just copy the whole dir you listed then copy it back to the new computer before you fire up 123 for the first time and you are good to go.  Well to be clear I would backup all of C:\Users\<username>\ArcGIS just to be safe since you may have other stuff in there.  But I would only copy the My Survey Designs back.
There is a post on it here somewhere to search for.
DougBrowning
RyanBohan
Awesome, thank you Doug, and will do
