What kind of error is this? (I attached image)
2158
01-19-2017 11:08 PM
AdministratorAGOL_ODIMM
#error1000 survey123 web
Error appear when survey is filling by users. The form is public.
JamesTedrick
Esri Esteemed Contributor
Hi Igor,
The issue is likely caused by the text being submitted being too long (Troubleshoot—Survey123 for ArcGIS | ArcGIS ).  When authored from the web, the single line text question can accept a maximum of 255 characters.  If you expect responses longer than that, use the multiline text can accept 1000 characters.
Surveys published with Survey123Connect can be configured with user-defined character limits.
JamesTedrick
Hi Igor,
Thanks James for your answer.
